Recommend: vaporesso xros series!
dysdylcom
СообщениеДобавлено: Sat Dec 03, 2022 2:09 pm    Заголовок сообщения: Recommend: vaporesso xros series! Ответить с цитатой
The products I'm going to introduce today are a very popular collection on our website: vaporesso xros. BUY 1 GET 2(The color of the gift will be sent randomly, and it will be added in the package.) 4 days limited time promotion. 10% OFF Sitewide (No coupon code required, total discount amount can be found at your shopping cart.)Date: December 1st - December 4th.
vaporesso xros pod
Details:
The Vaporesso XROS Pod Kit is composed of 800mAh battery which can provide 20W max output and 2ml pod cartridge. And the Vaporesso XROS battery is equipped with Axon Chip provideing multiple protections to avoid potential risks. As for the pod cartridge, it comes with top filling system and visible window design, both of which bring you great convenience. And there are 2 types of mesh coil available: 0.8ohm and 1.2ohm. It also adopts adjustable airflow toggle that maximizes the effectiveness of flavor and nic satisfaction to cover your needs. In addition, the Vaporesso XROS possesses 3-color LED Battery Indicator to show the battery usage. The Vaporesso XROS Pod comes with 1.2ohm Mesh POD and 0.8ohm Mesh POD for your choice. Moreover, monitored by AXON Chip, it guarantees your safety through multiple protections.
vaporesso xros mini
Details:
Vaporesso XROS MINI Kit continues the stable and superior performance of the XROS series, which provides the best MTL vaping experience. Comes with a compact and portable design, the luxury diamond pattern surface gives it a prestigious look and it's great non-slip and overall feeling in hand. XROS MINI Kit has a built-in 1000mAh battery that provides a significant improvement for the XROS MINI and can offer nearly 2 days without recharging and supports 5V/1A Type-C fast charging. The 2ml Pod, the clamshell top filling design is extremely easy to refill your e-juice. Equipped with SSS Leak-Resistant Technology; What's more, The equipped XROS pods can be compatible with the whole XROS family, which enhances both flavor and nic delivery for your Vaping experience. Built-in a 1.2ohm coil, XROS MINI Kit offers an uncommon MTL vaping experience. Sure, it is faster and even heating provides even better flavor through a 0.8Ω mesh pod (Sold separately).
For other vaporesso xros brand products, please click the link below for details:
vaporesso xros 2
vaporesso xros 3
